Zum Hauptinhalt wechseln
Kindle Fire HDX 7" Micro USB Charging Port Replacement
Was du brauchst
  1. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: Schritt 1, Bild 1 von 3 Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: Schritt 1, Bild 2 von 3 Kindle Fire HDX 7" Micro USB Charging Port Replacement, Speaker Bezel: Schritt 1, Bild 3 von 3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Micro USB Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Rear Panel: Schritt 3, Bild 1 von 1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Micro USB Charging Port Replacement: Schritt 4, Bild 1 von 2 Kindle Fire HDX 7" Micro USB Charging Port Replacement: Schritt 4, Bild 2 von 2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Micro USB Charging Port Replacement: Schritt 5, Bild 1 von 1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Micro USB Charging Port Replacement, Micro USB Charging Port: Schritt 7, Bild 1 von 1
    • Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
  7. Kindle Fire HDX 7" Micro USB Charging Port Replacement: Schritt 8, Bild 1 von 2 Kindle Fire HDX 7" Micro USB Charging Port Replacement: Schritt 8, Bild 2 von 2
    • Pry up the ribbon cable from the rear panel with the flat end of a spudger.
    • Remove the micro USB port and power button ribbon cable.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Blake Klein
70.531 Reputation
50 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 32
Insgesamt: 6,464
