Einleitung
Replacement guide for the micro USB charging port on a Kindle Fire HDX 7” tablet.
The home button and micro USB are part of the same ribbon cable and are replaced at the same time.
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Wedge opening picks around the perimeter between the display and back case.
Work the opening picks around the perimeter until the two halves disengage from each other.
Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
Pry up the ribbon cable from the rear panel with the flat end of a spudger.
Remove the micro USB port and power button ribbon cable.
4 weitere Nutzer haben diese Anleitung absolviert.
