Einleitung
Is your Kindle Fire HDX 7” not listening to you anymore? Don’t pull out the sleeper sofa just yet.
Replace the microphone by following this guide and see if it restores the communication between you and your tablet.
Was du brauchst
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Wedge opening picks around the perimeter between the display and back case.
Work the opening picks around the perimeter until the two halves disengage from each other.
Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
