Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
The first step to every electronic repair is to turn it off and back on again. But, this is only possible if your power button works.
If it’s broken, follow this guide to replace the power button on your Kindle Fire HDX 7” tablet.
  1. Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet. The adhesive is strong and may require an iOpener, or heat gun, to soften. The adhesive is strong and may require an iOpener, or heat gun, to soften.
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Remove the speaker bezel.
    • Remove the speaker bezel.
  3. Remove the six pink 3mm T3 Torx screws from the back case.
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Wedge opening picks around the perimeter between the display and back case. Work the opening picks around the perimeter until the two halves disengage from each other.
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
    • Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
  7. Pry up the ribbon cable from the rear panel with the flat end of a spudger. Remove the micro USB port and power button ribbon cable.
    • Pry up the ribbon cable from the rear panel with the flat end of a spudger.
    • Remove the micro USB port and power button ribbon cable.
  8. Remove the power button from the rear panel.
    • Remove the power button from the rear panel.
Abschluss
Blake Klein
61.266 Reputation
57 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 298
