Einleitung
Is your Kindle Fire HDX 7” tablet refusing to get louder or quitter at the push of its buttons? The ribbon cable or buttons may be broken.
Follow this guide to replace them yourself!
Was du brauchst
Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
Wedge opening picks around the perimeter between the display and back case.
Work the opening picks around the perimeter until the two halves disengage from each other.
Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
Remove the two 2.1mm T5 Torx screws from the volume button retaining bracket.
Pry up the volume button ribbon cable from the rear panel with the flat end of a spudger.
Pull up on the volume button ribbon cable to remove it from the tablet.
