Zum Hauptinhalt wechseln
Kindle Paperwhite 1st Generation Case Replacement
Was du brauchst
  1. Kindle Paperwhite 1st Generation Case Replacement, Case: Schritt 1, Bild 1 von 2 Kindle Paperwhite 1st Generation Case Replacement, Case: Schritt 1, Bild 2 von 2
    • Using a spudger or plastic opening tool, gently pry the bezel from the screen. It is easier to start in the corners and work your way around the bezel.
    • Do not insert the spudger too far under the bezel; it could easily damage the screen.
  2. Kindle Paperwhite 1st Generation Case Replacement: Schritt 2, Bild 1 von 3 Kindle Paperwhite 1st Generation Case Replacement: Schritt 2, Bild 2 von 3 Kindle Paperwhite 1st Generation Case Replacement: Schritt 2, Bild 3 von 3
    • Remove the eleven 3.0 mm Phillips screws surrounding the midframe.
    • At the top of the display, a strip of black tape covers one screw.
  3. Kindle Paperwhite 1st Generation Case Replacement: Schritt 3, Bild 1 von 1
    • Lift the midframe out of the case.
    • If the midframe is stuck, slide it to the left first, and then lift it out.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 3-33, Amido Winter 2013 Mitglied von Cal Poly, Team 3-33, Amido Winter 2013
CPSU-AMIDO-W13S3G33
4 Mitglieder
17 Anleitungen geschrieben
2 Kommentare
Thanks for the guide but do you know anywhere can we get a replacement case?
jerryw - Antwort
4 years too late but I found this
Pao-Tang Kao - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 22
Letzte 30 Tage: 87
Insgesamt: 9,222
