Zum Hauptinhalt wechseln
Kindle Paperwhite 2nd Generation Battery Replacement
Was du brauchst
  1. Kindle Paperwhite 2nd Generation Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Kindle Paperwhite 2nd Generation Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the outer edges , these are the optimal points for removing the bezel.
    • Be careful and do not slide prying tool deeper than 3-4 mm under the side bezel or you could peel off screen protector film.
  2. Kindle Paperwhite 2nd Generation Battery Replacement: Schritt 2, Bild 1 von 2 Kindle Paperwhite 2nd Generation Battery Replacement: Schritt 2, Bild 2 von 2
    • Using a Screw Driver, Remove the eleven 3.2 mm Phillips 000 screws from corners of the mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Battery Replacement: Schritt 3, Bild 1 von 1
    • Carefully remove the mid-frame from the back cover.
  4. Kindle Paperwhite 2nd Generation Battery Replacement: Schritt 4, Bild 1 von 2 Kindle Paperwhite 2nd Generation Battery Replacement: Schritt 4, Bild 2 von 2
    • Use a screwdriver to remove the three 3.0 mm Phillips 000 screws that are holding the battery in place as shown.
  5. Kindle Paperwhite 2nd Generation Battery Replacement: Schritt 5, Bild 1 von 1
    • Carefully lift the battery and remove it from the device.
Abschluss
24 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler Davis
1.574 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 11-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Mitglieder
7 Anleitungen geschrieben
7 Kommentare
Do you have a source for the battery itself? Thank you.
mattstonecash - Antwort
I’ve done this on two different Kindles with the same result: dead kindle. No matter how long it stays on the charger, the light stays amber. Screen will not change. Hard reset seems to do nothing; the light flashes, but no change. One Paperwhite even got a new motherboard. This is crazy! Is it possible to fix one, do I have to just buy another!?
Adam Britt - Antwort
I'm probably 7 years too late but this was the case with one I got from Goodwill and plugging it into a higher amperage charger (2.4A) seemed to do the trick. When you plug it in it charges until there is enough power for it to boot up and when that happens it ends up draining the little bit that was there so it just gets stuck in a loop. You just have to give it more power to work with.
Ellis Bowser -
Hi Adam,
I have the same issue, the light is orange but the Kindle won’t turn on. I ordered the battery at www.batteryupgrade.com. But they have some misleading info on their website so they sent me the wrong battery even if it states that it supports Kindle Paperwhite 2012. Check the connections on original and on the new battery. In my case the battery looks the same, but the connections doesn’t. Now I’m waiting for the new one …
Regards.
Andrej Mihelic - Antwort
Did replacement of battery help you to resolve problem?
behemothkat -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 89
Letzte 30 Tage: 466
Insgesamt: 17,309
