Zum Hauptinhalt wechseln
Kindle Paperwhite 2nd Generation Power Button Replacement
Was du brauchst
    1. Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: Schritt 1, Bild 1 von 2 Kindle Paperwhite 2nd Generation Power Button Replacement, Power Button: Schritt 1, Bild 2 von 2
      • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
      • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
      Frag FixBot
      Kommentar hinzufügen
    2. Kindle Paperwhite 2nd Generation Power Button Replacement: Schritt 2, Bild 1 von 2 Kindle Paperwhite 2nd Generation Power Button Replacement: Schritt 2, Bild 2 von 2
      • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
      • Do not forget the screw in the middle of the black adhesive strip.
      Frag FixBot
    3. Kindle Paperwhite 2nd Generation Power Button Replacement: Schritt 3, Bild 1 von 1
      • Carefully lift and remove the mid-frame.
      Frag FixBot
    4. Kindle Paperwhite 2nd Generation Power Button Replacement: Schritt 4, Bild 1 von 2 Kindle Paperwhite 2nd Generation Power Button Replacement: Schritt 4, Bild 2 von 2
      • Remove the power button carefully using a blue plastic opening tool, and replace with a functional unit.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 11-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Mitglieder
60 Anleitungen geschrieben
5 Kommentare zur Anleitung
I have problems with my power button and this is very nice presentation, but I would like to know whether this button is an integral part of the back cover or can be purchased separately and, of course, where it can be purchased.
Thank you for answer and best regards,
Bojan
Bojan Briški - Antwort Teilen
Seconding this: where exactly can I purchase the button?
Oren Leifer - Antwort Teilen
Same for me…..where can I buy this button?
Rob Hoenstok - Antwort Teilen
The power button must be part of an assembly that attaches to the main board in order for it to function. Where can I buy this assembly and not just the plastic button itself?
Roger Joseph
Roger joseph - Antwort Teilen
This information is not useful unless the author tells us where to buy the power buttin.
Calvin Jordan - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 29
Letzte 30 Tage: 105
Insgesamt: 6,416
