Zum Hauptinhalt wechseln
Kindle Paperwhite 2nd Generation Screen Replacement
Was du brauchst
  1. Kindle Paperwhite 2nd Generation Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Insert plastic opening tool into the corners of the Paperwhite and slide around the edge perimeter to remove bezel.
    • Be sure to begin prying along the edges, these are the optimal points for removing the bezel.
  2. Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 2, Bild 1 von 2 Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the eleven 3.2 mm Phillips 000 screws from corners of mid-frame and from behind the black strip as shown.
    • Do not forget the screw in the middle of the black adhesive strip.
  3. Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 3, Bild 1 von 1
    • Carefully lift and remove the mid-frame.
  4. Kindle Paperwhite 2nd Generation Screen Replacement: Schritt 4, Bild 1 von 1
    • The screen itself is glued to the mid-frame. If your replacement screen does not include the mid-frame, heat the screen with an iOpener and gently pry it from the mid-frame with a blue plastic opening tool.
Abschluss
6 weitere Personen haben diese Anleitung absolviert.
Tyler Davis
1.697 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 11-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 11-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S11G2
4 Mitglieder
17 Anleitungen geschrieben
3 Kommentare
My opening tool is orange. Will this still work for me?
FoxRunTime - Antwort
I’m hoping to replace my screen with this part:
Kindle Paperwhite (2nd Gen) Display
Does this part include the mid-frame? I would like to avoid using the iOpener if possible.
Thank you!
Liam Cahill - Antwort
Did this work Liam?
Ben Lowdon -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 30
Letzte 30 Tage: 132
Insgesamt: 12,819
