Einleitung
Next to the battery is the 3G unit. However, in the
models that are WiFi only, there will instead be a plastic placeholder instead. The replacement instructions for both are identical.
Was du brauchst
Einführungsvideo
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Slide the back panel downward, toward the charging port. This will release the clips on the top half.
Once the top clips release, gently lift the back panel away.
Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
Next, gently lift the 3G assembly with a Spudger or your fingers.
Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
