Zum Hauptinhalt wechseln
Kindle Touch 3G Card Housing Replacement
Was du brauchst
Einführungsvideo
  1. Kindle Touch 3G Card Housing Replacement, Back Cover: Schritt 1, Bild 1 von 3 Kindle Touch 3G Card Housing Replacement, Back Cover: Schritt 1, Bild 2 von 3 Kindle Touch 3G Card Housing Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch 3G Card Housing Replacement: Schritt 2, Bild 1 von 2 Kindle Touch 3G Card Housing Replacement: Schritt 2, Bild 2 von 2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch 3G Card Housing Replacement, Battery: Schritt 3, Bild 1 von 3 Kindle Touch 3G Card Housing Replacement, Battery: Schritt 3, Bild 2 von 3 Kindle Touch 3G Card Housing Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch 3G Card Housing Replacement: Schritt 4, Bild 1 von 3 Kindle Touch 3G Card Housing Replacement: Schritt 4, Bild 2 von 3 Kindle Touch 3G Card Housing Replacement: Schritt 4, Bild 3 von 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: Schritt 5, Bild 1 von 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: Schritt 5, Bild 2 von 3 Kindle Touch 3G Card Housing Replacement, Remove the 3G Board: Schritt 5, Bild 3 von 3
    • Remove the indicated four 2 mm screws with a Phillips #00 screwdriver. (Units with the 3G assembly have Phillips #000 screws.)
    • Next, gently lift the 3G assembly with a Spudger or your fingers.
    • This Kindle Touch is the WiFi only model and comes with a plastic placeholder instead of the 3G assembly.
    • Disconnect the antenna lead by carefully prying it off the 3G board with a plastic tool.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Adam Yerly
2.031 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 19-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Mitglieder
8 Anleitungen geschrieben
2 Kommentare zur Anleitung
Hey, thanks for your guide!
I, however, have one question, maybe I misunderstood - is it possible to add a 3G module to a kindle touch that didn't have one installed by default?
Would it work?
Curious_Guy_Threepwood - Antwort
You would need to add more than just a 3G module - there’s a slot for a SIM-card tray and special Amazon SIM that are missing from non-3G Kindle Touches. I don’t know if there would be any software changes that would need making.
Darren John de Lima -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 28
Insgesamt: 2,530
