Einleitung
Use this guide to replace an old or faulty Amazon Kindle Touch battery. The battery may be due for replacement if your Kindle runs out of power quickly, won’t work unless plugged in, or won’t charge.
Make sure the device is powered off and disconnected from all external power sources before beginning this process. Please dispose of electronic waste responsibly.
Was du brauchst
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Slide the back panel downward, toward the charging port. This will release the clips on the top half.
Once the top clips release, gently lift the back panel away.
18 weitere Personen haben diese Anleitung absolviert.
