Zum Hauptinhalt wechseln
Kindle Touch Battery Replacement
Was du brauchst
  1. Kindle Touch Battery Replacement, Back Cover: Schritt 1, Bild 1 von 3 Kindle Touch Battery Replacement, Back Cover: Schritt 1, Bild 2 von 3 Kindle Touch Battery Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch Battery Replacement: Schritt 2, Bild 1 von 2 Kindle Touch Battery Replacement: Schritt 2, Bild 2 von 2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch Battery Replacement, Battery: Schritt 3, Bild 1 von 3 Kindle Touch Battery Replacement, Battery: Schritt 3, Bild 2 von 3 Kindle Touch Battery Replacement, Battery: Schritt 3, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Battery Replacement: Schritt 4, Bild 1 von 3 Kindle Touch Battery Replacement: Schritt 4, Bild 2 von 3 Kindle Touch Battery Replacement: Schritt 4, Bild 3 von 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
Abschluss
22 weitere Personen haben diese Anleitung absolviert.
Adam Yerly
2.031 Reputation
7 Anleitungen geschrieben
USF Tampa, Team 19-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Mitglieder
8 Anleitungen geschrieben
2 Kommentare zur Anleitung
Where can I buy a new battery?
Carla Grobler (Ubbink) - Antwort Teilen
I tried this, but my Kindle still wouldn't work so it must not have been the battery. I'm happy to mail the new battery and the tools that came with it to whoever needs them if shipping isn't too expensive from California. Reach me at meldmb9-at-hotmail-dot-com subject line "kindle battery".
TryingToFix - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 48
Letzte 30 Tage: 202
Insgesamt: 13,231
