Einleitung
This guide will cover how to remove and replace the bezel on a Kindle Touch and requires using a plastic opening tool and PH00 screwdriver.
Was du brauchst
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Slide the back panel downward, toward the charging port. This will release the clips on the top half.
Once the top clips release, gently lift the back panel away.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
4 weitere Personen haben diese Anleitung absolviert.
