Einleitung
Should the user wish to replace the casing or access the further internals, this guide will be useful.
Was du brauchst
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Slide the back panel downward, toward the charging port. This will release the clips on the top half.
Once the top clips release, gently lift the back panel away.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
Eine weitere Person hat diese Anleitung absolviert.
