Einleitung
Use this guide to properly replace your speakers.
Was du brauchst
Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
Slide the back panel downward, toward the charging port. This will release the clips on the top half.
Once the top clips release, gently lift the back panel away.
Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
The speakers are held down solely with contact adhesive, so use your Spudger to pry them from the support board.
