Zum Hauptinhalt wechseln
Kindle Touch Speaker Replacement
Was du brauchst
    1. Kindle Touch Speaker Replacement, Back Cover: Schritt 1, Bild 1 von 3 Kindle Touch Speaker Replacement, Back Cover: Schritt 1, Bild 2 von 3 Kindle Touch Speaker Replacement, Back Cover: Schritt 1, Bild 3 von 3
      • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
      • Don't pry the clips on the top half of the back panel.
      Frag FixBot
      Kommentar hinzufügen
    2. Kindle Touch Speaker Replacement: Schritt 2, Bild 1 von 2 Kindle Touch Speaker Replacement: Schritt 2, Bild 2 von 2
      • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
      • Once the top clips release, gently lift the back panel away.
      Frag FixBot
    1. Kindle Touch Speaker Replacement, Battery: Schritt 3, Bild 1 von 3 Kindle Touch Speaker Replacement, Battery: Schritt 3, Bild 2 von 3 Kindle Touch Speaker Replacement, Battery: Schritt 3, Bild 3 von 3
      • Use a Phillips #00 screwdriver to remove the five screws.
      Frag FixBot
    2. Kindle Touch Speaker Replacement: Schritt 4, Bild 1 von 3 Kindle Touch Speaker Replacement: Schritt 4, Bild 2 von 3 Kindle Touch Speaker Replacement: Schritt 4, Bild 3 von 3
      • Using the flat end of your spudger, gently pry the battery up and remove it.
      Frag FixBot
    1. Kindle Touch Speaker Replacement, Bezel: Schritt 5, Bild 1 von 2 Kindle Touch Speaker Replacement, Bezel: Schritt 5, Bild 2 von 2
      • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
      Frag FixBot
    2. Kindle Touch Speaker Replacement: Schritt 6, Bild 1 von 3 Kindle Touch Speaker Replacement: Schritt 6, Bild 2 von 3 Kindle Touch Speaker Replacement: Schritt 6, Bild 3 von 3
      • Use the plastic opening tool to pry the bezel from the top and sides
      • The bottom of the bezel will be glued, so be careful when sliding the clips out.
      • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
      Frag FixBot
    1. Kindle Touch Speaker Replacement, Rear Casing: Schritt 7, Bild 1 von 1
      • Use your Phillips #00 srewdriver to remove the indicated screws.
      • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
      Frag FixBot
    2. Kindle Touch Speaker Replacement: Schritt 8, Bild 1 von 2 Kindle Touch Speaker Replacement: Schritt 8, Bild 2 von 2
      • With the screws removed, gently remove the case from the internals.
      Frag FixBot
    1. Kindle Touch Speaker Replacement, Speaker: Schritt 9, Bild 1 von 3 Kindle Touch Speaker Replacement, Speaker: Schritt 9, Bild 2 von 3 Kindle Touch Speaker Replacement, Speaker: Schritt 9, Bild 3 von 3
      • Use the pointy end of your Spudger to separate the Speaker's connector from the motherboard on both sides.
      Frag FixBot
    2. Kindle Touch Speaker Replacement: Schritt 10, Bild 1 von 3 Kindle Touch Speaker Replacement: Schritt 10, Bild 2 von 3 Kindle Touch Speaker Replacement: Schritt 10, Bild 3 von 3
      • The speakers are held down solely with contact adhesive, so use your Spudger to pry them from the support board.
      Frag FixBot
Abschluss
USF Tampa, Team 19-5, Blackwell Winter 2015 Mitglied von USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 32
Insgesamt: 1,573
