Zum Hauptinhalt wechseln
Kindle Voyage Vibrator Replacement
Was du brauchst
  1. Kindle Voyage Vibrator Replacement, Back Panel: Schritt 1, Bild 1 von 2 Kindle Voyage Vibrator Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Vibrator Replacement: Schritt 2, Bild 1 von 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Vibrator Replacement: Schritt 3, Bild 1 von 3 Kindle Voyage Vibrator Replacement: Schritt 3, Bild 2 von 3 Kindle Voyage Vibrator Replacement: Schritt 3, Bild 3 von 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Vibrator Replacement: Schritt 4, Bild 1 von 2 Kindle Voyage Vibrator Replacement: Schritt 4, Bild 2 von 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Vibrator Replacement, Vibrator: Schritt 5, Bild 1 von 2 Kindle Voyage Vibrator Replacement, Vibrator: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to pinch in the sides of the vibrator cable and slide it out of its housing.
  6. Kindle Voyage Vibrator Replacement: Schritt 6, Bild 1 von 3 Kindle Voyage Vibrator Replacement: Schritt 6, Bild 2 von 3 Kindle Voyage Vibrator Replacement: Schritt 6, Bild 3 von 3
    • Gently peel the vibrator off of the device.
Abschluss
Sean Yap
1.351 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 19-12, Maness Winter 2015 Mitglied von Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
OK, the procedure seems straightforward enough, but you say “no parts required” when you actually *do* need to buy the replacement parts for the pieces that are no longer functioning. Where can you buy these parts?
Sharon Crowley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 1,261
