Einleitung
If your Kingston HyperX Cloud II microphone is having connection issues, use this guide to replace or reconnect your microphone wire to the driver. Inside the driver, the red wire is the wire that must be soldered to the driver for the microphone to be repaired. This problem occurs when the red wire gets disconnected from the speaker or stops working from natural causes.
Was du brauchst
Pulling along the edges, take off the padding.
Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
Remove the inside bracket support and then remove the outside bracket support. Then set it to the side.
After removing the bracket support. Expand and remove the microphone speaker from the frame.
Use a Phillips #1 screwdriver to remove the two 7.9 mm screws from the red support attached to the microphone speaker.
Separate the red frame support from the microphone speaker by putting it to the side.
Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
Remove the microphone speaker frame.
Open the microphone speaker to reveal circuitry.
Solder the detached red wire onto the driver.
