Zum Hauptinhalt wechseln
Kingston HyperX Cloud II Speaker Wire Repair
Was du brauchst
  1. Kingston HyperX Cloud II Speaker Wire Repair, Kingston HyperX Cloud II Speaker Wire Repair: Schritt 1, Bild 1 von 1
    • Pulling along the edges, take off the ear padding.
  2. Kingston HyperX Cloud II Speaker Wire Repair: Schritt 2, Bild 1 von 2 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
  3. Kingston HyperX Cloud II Speaker Wire Repair: Schritt 3, Bild 1 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 3, Bild 2 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 3, Bild 3 von 3
    • Remove the inside bracket support, and then remove the outside bracket support.
    • Expand and remove the microphone speaker from the frame.
  4. Kingston HyperX Cloud II Speaker Wire Repair: Schritt 4, Bild 1 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 4, Bild 2 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 4, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove the two 7.90 mm screws from the red support attached to the microphone speaker.
  5. Kingston HyperX Cloud II Speaker Wire Repair: Schritt 5, Bild 1 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 5, Bild 2 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 5, Bild 3 von 3
    • Separate the red frame support from the microphone speaker by putting it to the side.
  6. Kingston HyperX Cloud II Speaker Wire Repair: Schritt 6, Bild 1 von 2 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 6, Bild 2 von 2
    • Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
  7. Kingston HyperX Cloud II Speaker Wire Repair: Schritt 7, Bild 1 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 7, Bild 2 von 3 Kingston HyperX Cloud II Speaker Wire Repair: Schritt 7, Bild 3 von 3
    • Remove the headphone speaker frame.
    • Solder the detached blue wire onto the driver.
    • Be cautious not to solder the wrong wire.
  8. Kingston HyperX Cloud II Speaker Wire Repair: Schritt 8, Bild 1 von 1
    • Solder the green wire onto the driver.
Abschluss
IUPUI, Team 1-4, Harley Spring 2023 Mitglied von IUPUI, Team 1-4, Harley Spring 2023
IUPUI-HARLEY-S23S1G4
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 121
Insgesamt: 1,864
