Einleitung
If your Kingston HyperX Cloud II speaker is having connection issues, use this guide to reconnect your speaker wire to the driver. The blue and green wires are the wires that must be soldered to fix the speaker feedback for the speakers to be repaired. This problem occurs when the wires get disconnected from the speaker or stop working from natural causes.
Was du brauchst
Pulling along the edges, take off the ear padding.
Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
Remove the inside bracket support, and then remove the outside bracket support.
Expand and remove the microphone speaker from the frame.
Use a Phillips #1 screwdriver to remove the two 7.90 mm screws from the red support attached to the microphone speaker.
Separate the red frame support from the microphone speaker by putting it to the side.
Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
Remove the headphone speaker frame.
Solder the detached blue wire onto the driver.
