Zum Hauptinhalt wechseln
Kitchen Faucet Replacement
Was du brauchst
  1. Kitchen Faucet Replacement, Kitchen Faucet: Schritt 1, Bild 1 von 3 Kitchen Faucet Replacement, Kitchen Faucet: Schritt 1, Bild 2 von 3 Kitchen Faucet Replacement, Kitchen Faucet: Schritt 1, Bild 3 von 3
    • Rotate the hot and cold water valve knobs under the sink clockwise to turn off the water.
    • Turn on the faucet to relieve the pressure and any remaining water for about one minute.
    Frag FixBot
    Kommentar hinzufügen
  2. Kitchen Faucet Replacement: Schritt 2, Bild 1 von 3 Kitchen Faucet Replacement: Schritt 2, Bild 2 von 3 Kitchen Faucet Replacement: Schritt 2, Bild 3 von 3
    • Place a bucket underneath the valves to catch dripping water.
    • Turn the hot and cold supply line nuts clockwise until the water supply lines come out.
    • For a pull-down faucet, disconnect the spray hose from both the spray head and the main body.
    Frag FixBot
  3. Kitchen Faucet Replacement: Schritt 3, Bild 1 von 3 Kitchen Faucet Replacement: Schritt 3, Bild 2 von 3 Kitchen Faucet Replacement: Schritt 3, Bild 3 von 3
    • Loosen and remove the nuts underneath the sink by using an adjustable wrench.
    • Remove the mounting bracket.
    Frag FixBot
  4. Kitchen Faucet Replacement: Schritt 4, Bild 1 von 2 Kitchen Faucet Replacement: Schritt 4, Bild 2 von 2
    • Use your hands to pull the faucet out of the sink.
    • Clean away any grime or sealant with a cleaning spray and towel.
    Frag FixBot
  5. Kitchen Faucet Replacement: Schritt 5, Bild 1 von 3 Kitchen Faucet Replacement: Schritt 5, Bild 2 von 3 Kitchen Faucet Replacement: Schritt 5, Bild 3 von 3
    • Place the trim ring on the faucet hole.
    • Feed the faucet into the faucet hole and position it.
    • Different faucets install differently, so be sure to read and follow the instructions for your faucet.
    Frag FixBot
  6. Kitchen Faucet Replacement: Schritt 6, Bild 1 von 2 Kitchen Faucet Replacement: Schritt 6, Bild 2 von 2
    • Underneath the sink, put the mounting bracket back in place, and turn the nuts to tighten them.
    Frag FixBot
  7. Kitchen Faucet Replacement: Schritt 7, Bild 1 von 3 Kitchen Faucet Replacement: Schritt 7, Bild 2 von 3 Kitchen Faucet Replacement: Schritt 7, Bild 3 von 3
    • Hook the water supply lines up by turning the hot and cold supply line nuts counter clockwise.
    • For pull-down faucets, attach the weight kit on the spray hose and connect it to both the spray head and the pull-out hose.
    Frag FixBot
  8. Kitchen Faucet Replacement: Schritt 8, Bild 1 von 3 Kitchen Faucet Replacement: Schritt 8, Bild 2 von 3 Kitchen Faucet Replacement: Schritt 8, Bild 3 von 3
    • Rotate the hot and cold water valve knobs counter clockwise to turn on the water under the sink.
    • Once it is all done, check if there are any leaks.
    Frag FixBot
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
York University, Team S3-G47, Melo-Thaiss Fall 2020 Mitglied von York University, Team S3-G47, Melo-Thaiss Fall 2020
YORK-MELO-THAISS-F20S3G47
1 Mitglied
12 Anleitungen geschrieben
1 Kommentar zur Anleitung
Great guide on kitchen faucet replacement! I was able to follow the steps and successfully replace my old faucet with a new one. The pictures and detailed instructions made the process much easier. Thank you for sharing this useful information!
Scott Robillard - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 46
Letzte 7 Tage: 103
Letzte 30 Tage: 170
Insgesamt: 1,572
