Einleitung
This is a disassembly guide for the Kitchen Gourmet Electric Hot Pot Model No. WM-6105 that allows you to access all of the components without permanently damaging any of them. This disassembly only requires use of a screwdriver. Further disassembly to replace individual components would require soldering, which is not covered in this guide.
Was du brauchst
Remove the 7 12 mm Phillips #1 screws.
The white plastic bar holding two of the screws comes loose once they are unscrewed.
Unscrew the single screw holding down the clamp that connects the thermal switch (black cylinder) and the white wire to the body of the hot pot.
