Zum Hauptinhalt wechseln
Kitchen Sink Basket Strainer Replacement
Was du brauchst
  1. Kitchen Sink Basket Strainer Replacement, Basket Strainer: Schritt 1, Bild 1 von 1
    • Shut off the hot and cold water supply valves under the sink.
    • Turn the handles clockwise and make sure the water is off before moving on.
  2. Kitchen Sink Basket Strainer Replacement: Schritt 2, Bild 1 von 2 Kitchen Sink Basket Strainer Replacement: Schritt 2, Bild 2 von 2
    • Remove the stopper from the basket strainer by lifting it out.
  3. Kitchen Sink Basket Strainer Replacement: Schritt 3, Bild 1 von 2 Kitchen Sink Basket Strainer Replacement: Schritt 3, Bild 2 von 2
    • Loosen the trap adapter nut under the sink.
    • Use the pliers and turn counterclockwise to loosen the nut.
  4. Kitchen Sink Basket Strainer Replacement: Schritt 4, Bild 1 von 2 Kitchen Sink Basket Strainer Replacement: Schritt 4, Bild 2 von 2
    • Loosen the tailpiece nut under the basket strainer.
  5. Kitchen Sink Basket Strainer Replacement: Schritt 5, Bild 1 von 2 Kitchen Sink Basket Strainer Replacement: Schritt 5, Bild 2 von 2
    • Loosen the nut of the basket strainer.
  6. Kitchen Sink Basket Strainer Replacement: Schritt 6, Bild 1 von 1
    • Remove the basket strainer from the sink by lifting it out.
  7. Kitchen Sink Basket Strainer Replacement: Schritt 7, Bild 1 von 1
    • Remove the tailpiece from the trap adaptor by lifting it out.
    • Keep the trap adapter nut and the nylon slip washer aside.
    • The trap adapter nut and nylon slip washer are shown in the image. The nylon slip is within the trap adaptor.
  8. Kitchen Sink Basket Strainer Replacement: Schritt 8, Bild 1 von 2 Kitchen Sink Basket Strainer Replacement: Schritt 8, Bild 2 von 2
    • Clean the sink opening and install a new basket strainer and the tailpiece.
    • Image 2 shows all the pieces that should be included in your new kit.
  9. Kitchen Sink Basket Strainer Replacement: Schritt 9, Bild 1 von 1
    • Slide the old trap adaptor nut and nylon slip washer over the tailpiece.
  10. Kitchen Sink Basket Strainer Replacement: Schritt 10, Bild 1 von 1
    • Install the tailpiece into the trap adaptor with the tailpiece washer inserted on top.
  11. Kitchen Sink Basket Strainer Replacement: Schritt 11, Bild 1 von 1
    • Place the basket strainer on top of the tailpiece.
  12. Kitchen Sink Basket Strainer Replacement: Schritt 12, Bild 1 von 2 Kitchen Sink Basket Strainer Replacement: Schritt 12, Bild 2 von 2
    • Align the upper strainer to the basket under the sink and tighten it with the nut supplied.
    • Use the pliers and turn clockwise to tighten the nut.
  13. Kitchen Sink Basket Strainer Replacement: Schritt 13, Bild 1 von 1
    • Tighten the tailpiece nut to the basket.
  14. Kitchen Sink Basket Strainer Replacement: Schritt 14, Bild 1 von 1
    • Tighten the trap adaptor nut.
  15. Kitchen Sink Basket Strainer Replacement: Schritt 15, Bild 1 von 1
    • Insert the strainer and turn the water back on to test for any leaks.
Ziellinie
Daniel Mella
241 Reputation
1 Anleitung geschrieben
York University, Team F-6, Woodhouse Fall 2021 Mitglied von York University, Team F-6, Woodhouse Fall 2021
YORK-WOODHOUSE-F21SFG6
1 Mitglied
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 39
Insgesamt: 3,003
