Einleitung
In this guide, we will show you how to replace an overcharged, low-performance hard-rubber coupling in a Kitchen Aid Mixer 5KSB52 UltraPower.
Disconnect the blender from the power supply. Prepare tools and spare parts. Tools required: original spanner, small water pump tongs. Spare part: hard rubber coupling
Loosen the defective coupling with water pump tongs and original open-ended spanner. Hold the axis with an open-ended spanner and unscrew the coupling. Remove coupling.
Insert the new coupling and screw it on slightly. Screw the new coupling by hand with a spanner.
Repeat the steps in reverse order to reassemble your device.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
100%
Hier starten ›
