Zum Hauptinhalt wechseln
KitchenAid Classic Mixer K45SSWH Worm Gear Replacement
Was du brauchst
  1. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement, Motor Housing Cover: Schritt 1, Bild 1 von 2 KitchenAid Classic Mixer K45SSWH Worm Gear Replacement, Motor Housing Cover: Schritt 1, Bild 2 von 2
    • Using a spudger, gently pry off the aluminum drip ring.
  2. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 2, Bild 1 von 1
    • Using a 4 mm pin punch and hammer, hammer the pin until it is dislodged from the planetary gear cover.
  3. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 3, Bild 1 von 2 KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 3, Bild 2 von 2
    • Using a spudger, pry the planetary gear cover from the mixer shaft.
  4. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 4, Bild 1 von 1
    • Using a flathead screwdriver, remove the five 28 mm front motor housing screws.
    • Using the same flathead screwdriver, remove the two 28 mm locking screws.
    • One of the locking screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  5. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 5, Bild 1 von 1
    • Turn your device around. Using the same flathead screwdriver, remove the two 28 mm rear locking screws.
    • One of the rear motor housing screws contains a safety locking mechanism. Do not interchange these screws with the front motor housing screws.
  6. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 6, Bild 1 von 2 KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 6, Bild 2 von 2
    • Using a Phillips #2 screwdriver, remove the 10 mm screw from top of back cover.
    • The rear cover is now completely free from the mixer.
  7. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 7, Bild 1 von 2 KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 7, Bild 2 von 2
    • Carefully pull the power cord from the notch in back of the mixer.
    • The motor housing cover is now completely free from the base of the mixer.
  8. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 8, Bild 1 von 1
    • Lift the motor housing cover from the mixer base.
    • Be sure to place the cover upside-down to prevent grease from leaking out.
  9. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement, Worm Gear: Schritt 9, Bild 1 von 2 KitchenAid Classic Mixer K45SSWH Worm Gear Replacement, Worm Gear: Schritt 9, Bild 2 von 2
    • Using a butter knife or putty knife, remove the grease from the gears.
    • Place the grease in motor housing cover.
  10. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 10, Bild 1 von 1
    • Using a Phillips #2 screwdriver, remove the three 20 mm screws from the worm gear tower.
    • The worm gear tower assembly is now free from the mixer base.
  11. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 11, Bild 1 von 2 KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 11, Bild 2 von 2
    • Using a pin punch and a hammer, remove the roll pin.
  12. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 12, Bild 1 von 1
    • Slide the tower gear out to access the worm gear.
  13. KitchenAid Classic Mixer K45SSWH Worm Gear Replacement: Schritt 13, Bild 1 von 1
    • Remove the worm gear from the tower.
Abschluss
57 weitere Nutzer:innen haben diese Anleitung absolviert.
Chris Grant
1.742 Reputation
1 Anleitung geschrieben
Cal Poly, Team 14-28, Maness Fall 2014 Mitglied von Cal Poly, Team 14-28, Maness Fall 2014
CPSU-MANESS-F14S14G28
4 Mitglieder
22 Anleitungen geschrieben
28 Kommentare
Some corrections:
Step 1 -- Suggest (as the Service Manual does) using a flat-blade screwdriver and tap it with a light hammer to drive the drip ring off.
Step 2 -- the correct size pin punch is 5/32"
Step 3 -- Using two flat-blade screwdrivers, one on each side, pry off the planetary.
A plastic spudger is likely to break. Two points of leverage opposits each other distributes the load and prevents to the planetary and its shaft.
Step 11 -- The proper punch size is 3/32"
Steps 12 & 13 -- There is a washer on each side of the worm gear. Retain these and place one on each side off the grar when reassembling.
A link to the Service Manual:
http://www.kitchenaidparts.eu/documents/...
Finkerbell - Antwort
Cheers Finkerbell,
Very helpful info, as was the main part of the guide.
Not sure what model number I was working on, but when I l lifted off the motor housing, there was still wires connected to the base.
Just be careful at this stage in case you have the same...
markguerin - Antwort
my model K5SS WH is the same as yours until step 5. It doesnt have the two bolts as shown in the picture for step 5 so i wasnt able to complete the repair. any suggestions.
sailsetter - Antwort
Wow! Lovely guide to easy maintenance, no plenty stories
Dennis - Antwort
This is the BEST! Thank you.
Advanamics - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 31
Letzte 7 Tage: 266
Letzte 30 Tage: 1,203
Insgesamt: 107,874
