Zum Hauptinhalt wechseln
KitchenAid KHM512ER Beater Rings Replacement
Was du brauchst
  1. KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: Schritt 1, Bild 1 von 2 KitchenAid KHM512ER Beater Rings Replacement, Beater Rings: Schritt 1, Bild 2 von 2
    • Insert the back of a plastic opening tool into one of the beater holes
    • Apply force to pull the circular plastic part off.
    • If necessary, use the other side of the plastic opening tool to pry the circular plastic part off.
  2. KitchenAid KHM512ER Beater Rings Replacement: Schritt 2, Bild 1 von 2 KitchenAid KHM512ER Beater Rings Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #2 screwdriver to remove the two 20mm screws holding the bottom plastic piece in place.
    • Remove the bottom plastic piece using a plastic opening tool.
  3. KitchenAid KHM512ER Beater Rings Replacement: Schritt 3, Bild 1 von 2 KitchenAid KHM512ER Beater Rings Replacement: Schritt 3, Bild 2 von 2
    • Using a Phillips 2 screwdriver, remove the three 20.0mm screws holding the motor assembly in place.
    • Use your hands to remove the motor assembly.
  4. KitchenAid KHM512ER Beater Rings Replacement: Schritt 4, Bild 1 von 2 KitchenAid KHM512ER Beater Rings Replacement: Schritt 4, Bild 2 von 2
    • Firmly grip the motor in your hand. Using pliers, pull the connectors off the motors.
    • Some force may be required. Be careful not to cut yourself on any electrical components.
  5. KitchenAid KHM512ER Beater Rings Replacement: Schritt 5, Bild 1 von 2 KitchenAid KHM512ER Beater Rings Replacement: Schritt 5, Bild 2 von 2
    • Lie the motor down flat on a table.
    • Using a pair of tweezers, remove the ring from the plastic knob.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Brad Daniels
621 Reputation
3 Anleitungen geschrieben
USF Tampa, Team 2-3, Sullivan Spring 2016 Mitglied von USF Tampa, Team 2-3, Sullivan Spring 2016
USFT-SULLIVAN-S16S2G3
3 Mitglieder
4 Anleitungen geschrieben
3 Kommentare
Anyone know of a site that sells replacement beater gears?
joescherzo - Antwort
Nice set by step process but where does one get the rings?
M Stevens - Antwort
try Sears parts.com
Yvette Tower - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 50
Insgesamt: 6,622
