Einleitung
The ribbon cable connects the logic board to the motor. It looks like a gray ribbon with a red stripe.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the glass container and place the blender upside down on a solid surface. Remove the four rubber feet using the needle nose pliers. Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
    • Remove the glass container and place the blender upside down on a solid surface.
    • Remove the four rubber feet using the needle nose pliers.
    • Remove the four #7.5 Phillips 25mm screws that were located underneath the rubber feet using the Phillips #2 screwdriver.
  2. Lift the back panel up, sliding it along the power cord.
    • Lift the back panel up, sliding it along the power cord.
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver. Remove the rubber O-ring by lifting it up.
    • Remove the two #6 Hex 82mm screws using the Phillips #2 screwdriver.
    • Remove the rubber O-ring by lifting it up.
  5. Remove the ribbon cable from the chassis by lifting it up.
    • Remove the ribbon cable from the chassis by lifting it up.
    • Remove the other end of the ribbon cable from the circuit board by lifting it up.
Abschluss
Cameron Geehr
709 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 12-5, Forte Fall 2014 Mitglied von Cal Poly, Team 12-5, Forte Fall 2014
CPSU-FORTE-F14S12G5
5 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 264
