Zum Hauptinhalt wechseln
KitchenAid KUDS01DJSS0 Electronic Control Board Replacement
Was du brauchst
  1. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: Schritt 1, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: Schritt 1, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement, Electronic Control Board: Schritt 1, Bild 3 von 3
    • Unplug the dishwasher or shut off the house circuit breaker for the dishwasher.
    • To verify that power is disconnected, make sure that the control panel doesn’t light up when you press a control button or the power button.
  2. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 2, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 2, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 2, Bild 3 von 3
    • Open the dishwasher door.
  3. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 3, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 3, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 3, Bild 3 von 3
    • Remove the four screws from each side of the dishwasher door (eight screws total).
    • Removing the three screws from each side of the dishwasher (six screws total).
    • Support the outer door panel with one hand as you remove the final two screws at the top of the dishwasher door.
    • There are total of sixteen (16) screws.
  4. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 4, Bild 1 von 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 4, Bild 2 von 2
    • Use your hands to pull off the outer door panel with the control panel.
  5. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 5, Bild 1 von 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the two white outer wires by pulling them out.
    • The two white connectors have the same size and are close together.
    • Use one hand to hold the control panel while disconnecting the electrical connections from the old board.
  6. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 6, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 6, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 6, Bild 3 von 3
    • Remove the white rectangular connector that has six colored wires connected to it.
  7. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 7, Bild 1 von 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 7, Bild 2 von 2
    • Use one hand to hold the control panel while detaching the black connector.
    • The black connector is the main connector to the control board.
  8. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 8, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 8, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 8, Bild 3 von 3
    • Detach the white and gray ribbon cable attached to the black connector.
  9. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 9, Bild 1 von 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 9, Bild 2 von 2
    • Use your hands to pull the electronic control board out the mounting slots.
  10. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 10, Bild 1 von 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 10, Bild 2 von 2
    • Push the new electronic control board into the mounting slots.
    • Slide it to the right to engage the locking tab until you hear a click.
  11. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 11, Bild 1 von 2 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 11, Bild 2 von 2
    • Reconnect the black connector wires to the new electronic control board.
  12. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 12, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 12, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 12, Bild 3 von 3
    • Reconnect the white rectangular connector with six wires to the new electronic control board.
  13. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 13, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 13, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 13, Bild 3 von 3
    • Reconnect the two white outer connector wires to the new electronic control board.
  14. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 14, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 14, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 14, Bild 3 von 3
    • Reinstall the outer door panel and control panel on the inner door panel and reattach the user interface control wire harness.
    • Reinstall the sixteen mounting screws.
  15. KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 15, Bild 1 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 15, Bild 2 von 3 KitchenAid KUDS01DJSS0 Electronic Control Board Replacement: Schritt 15, Bild 3 von 3
    • Connect the dishwasher and reset the circuit breaker for your house to restore electricity.
    • To verify that power is connected, make sure that the control panel does light up when you press a control button or the power button.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Thuan Trang
345 Reputation
1 Anleitung geschrieben
York University, Team S-29, Woodhouse Winter 2022 Mitglied von York University, Team S-29, Woodhouse Winter 2022
YORK-WOODHOUSE-W22SSG29
1 Mitglied
2 Anleitungen geschrieben
4 Kommentare
Excellent illustration!!!
KO SAMUEL TAK SHUN - Antwort
عمل فنى رائع وجميل وبدقة متناهية
khaliddabnoun - Antwort
عمل فنى جميل ورائع وبدقة متناهية
Excellent how to! However the part attached to purchase doesn’t look like the original control board. Help!
magdelena kormusis - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 37
Insgesamt: 1,309
