Zum Hauptinhalt wechseln
Knot Thread to the Fabric (2 Ways)
Was du brauchst
  1. Knot Thread to the Fabric (2 Ways), Secure knot type 1: Schritt 1, Bild 1 von 3 Knot Thread to the Fabric (2 Ways), Secure knot type 1: Schritt 1, Bild 2 von 3 Knot Thread to the Fabric (2 Ways), Secure knot type 1: Schritt 1, Bild 3 von 3
    • On the backside of the fabric, make a very small stitch.
    • Pull the thread through, leaving a short tail of approximately 1/2 inch (~13 mm) to 1 inch (~25 mm).
    • Make another small stitch in the same area. Leave the needle piercing the fabric without pulling it all the way through.
  2. Knot Thread to the Fabric (2 Ways): Schritt 2, Bild 1 von 3 Knot Thread to the Fabric (2 Ways): Schritt 2, Bild 2 von 3 Knot Thread to the Fabric (2 Ways): Schritt 2, Bild 3 von 3
    • Take the thread that's emerging from the stitch and wrap it around the needle.
    • Wrap the thread around the needle a second time.
    • Push the wrapped threads down towards the base of the needle where it's emerging from the fabric.
  3. Knot Thread to the Fabric (2 Ways): Schritt 3, Bild 1 von 1
    • Pull the needle through the loops and pull the thread tight. The knot will lay flush with the fabric.
    • This video shows how to start a stitch with secure knot type 1.
    • This video shows how to end a stitch with secure knot type 1.
  4. Knot Thread to the Fabric (2 Ways), Secure knot type 2: Schritt 6, Bild 1 von 2 Knot Thread to the Fabric (2 Ways), Secure knot type 2: Schritt 6, Bild 2 von 2
  5. Knot Thread to the Fabric (2 Ways): Schritt 7, Bild 1 von 2 Knot Thread to the Fabric (2 Ways): Schritt 7, Bild 2 von 2
    • Make another small stitch in the same area, across the first stitch.
    • Pull the thread through but don't pull it tight, leaving a small loop.
  6. Knot Thread to the Fabric (2 Ways): Schritt 8, Bild 1 von 2 Knot Thread to the Fabric (2 Ways): Schritt 8, Bild 2 von 2
    • Thread the needle through the loop that was created in the previous step.
    • Gently pull the needle through the loop without pulling the thread tight, keeping the thread loop intact.
  7. Knot Thread to the Fabric (2 Ways): Schritt 9, Bild 1 von 2 Knot Thread to the Fabric (2 Ways): Schritt 9, Bild 2 von 2
    • Thread the needle through the loop again in the same direction as the previous step.
    • Pull the thread tight to secure the knot. The knot will lay flush against the fabric.
    • This video shows how to start a stitch with secure knot type 2.
    • This video shows how to end a stitch with secure knot type 2.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
Clara Redwood
2.544 Reputation
18 Anleitungen geschrieben
Patagonia Mitglied von Patagonia
Community
17 Mitglieder
168 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 29
Letzte 30 Tage: 113
Insgesamt: 500
