Zum Hauptinhalt wechseln
Einleitung
This guide is a walkthrough on how to replace the lithium battery on your Kobo Arc 7. This guide requires fairly simple tools that are all found in the ifixit tool kit and is simple and easy to understand.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Kobo Arc K107 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Battery Replacement: Schritt 3, Bild 1 von 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Battery Replacement: Schritt 4, Bild 1 von 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
Abschluss
Stephen Pehl
282 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 4
Letzten 30 Tage: 37
Insgesamt: 188
