Zum Hauptinhalt wechseln
Kobo Arc K107 Screen Replacement
Was du brauchst
  1. Kobo Arc K107 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Peel the back cover off of the Kobo Arc by finding the lip in the cover and pulling back on it.
  2. Kobo Arc K107 Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the screws from the midframe.
  3. Kobo Arc K107 Screen Replacement: Schritt 3, Bild 1 von 1
    • Use a nylon spudger to pry up the battery from the device.
    • It will give some resistance as it is glued down.
    • Always use plastic or nylon prying tools around the battery. Metal tools can puncture a battery, potentially causing a fire.
  4. Kobo Arc K107 Screen Replacement: Schritt 4, Bild 1 von 1
    • Unplug the battery connector from the rest of the tablet.
    • Remove the battery from the tablet.
  5. Kobo Arc K107 Screen Replacement, Speaker: Schritt 5, Bild 1 von 2 Kobo Arc K107 Screen Replacement, Speaker: Schritt 5, Bild 2 von 2
    • Remove the screws that are attached to the grey plastic layer.
    • Remove the gray plastic layer.
  6. Kobo Arc K107 Screen Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the speakers from the tablet.
  7. Kobo Arc K107 Screen Replacement, Screen: Schritt 7, Bild 1 von 2 Kobo Arc K107 Screen Replacement, Screen: Schritt 7, Bild 2 von 2
    • Wedge a nylon spudger between the screen and the tablet.
    • Slide the spudger around the edges of the screen and remove it from the device.
Abschluss
Stephen Pehl
303 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021 Mitglied von UMass Dartmouth, Team 4-3, Gulbrandsen Fall 2021
UMASSD-GULBRANDSEN-F21S4G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 6
Letzten 30 Tage: 12
Insgesamt: 212
