Einleitung
Use this guide to replace the back cover on your Kobo Clara BW (N365B model) eReader.
Important: There are three Clara BW versions: N365, N365B, and P365. Check your eReader's model number (printed near the bottom of the rear case) before starting this guide. This guide is for the N365B model.
The back cover includes the external power button.
Note: Replacement back covers don't have a printed serial number, so you'll have to refer to your eReader's internal settings for your serial number after this repair.
Kobo supports their eReaders with a warranty. If your device is still under warranty, Kobo may be able to help. Before starting a repair, review your warranty information or check support documentation.
Note: Some photos used in this guide are of different Kobo Clara models. Any slight visual discrepancies won't affect the guide procedure.
Was du brauchst
Lay your eReader down so the back cover is facing up.
Insert the flat edge of an opening pick between the frame and the bottom left corner of the back cover.
Push the pick downwards at a slight angle until it slides under the back cover.
Slide the pick toward the bottom right corner to release the clips along the bottom edge.
Remove the pick and reinsert it under the bottom left corner.
Angle the pick flat under the back cover and rotate it around the bottom left corner to release its clips.
Slide the pick toward the top left corner to release the clips along the left edge.
Grip the left edge of the back cover and lift it away from the eReader to release the remaining clips.
Remove the back cover.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
