Zum Hauptinhalt wechseln
Kobo Glo HD Rear Cover Replacement
Was du brauchst
  1. Kobo Glo HD Rear Cover Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Kobo Glo HD Rear Cover Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Kobo Glo HD Rear Cover Replacement, Rear Cover: Schritt 1, Bild 3 von 3
    • If you haven't done so already, power off your eReader by holding down the power button for 3 seconds until the display refreshes to indicate that it has powered off.
    • Opening picks are required for this step as opening tools can be too wide to get into the gap between the rear cover and the side/front.
    • Start by inserting the pick into the area around the power button or Micro USB port.
    • Don't insert it too far, as that could result in damage to the power button, status indicator, and/or Micro USB port.
    • Then, slide the pick around to undo these clips.
  2. Kobo Glo HD Rear Cover Replacement: Schritt 2, Bild 1 von 3 Kobo Glo HD Rear Cover Replacement: Schritt 2, Bild 2 von 3 Kobo Glo HD Rear Cover Replacement: Schritt 2, Bild 3 von 3
    • The rear cover should then pop off.
Abschluss
Kevin Bhasi
1.262 Reputation
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 716
