Einleitung
This guide will help you fix a problem where the battery connection comes loose causing the Kobe Vox to not boot
You can also use this guide to replace the battery entirely.
Was du brauchst
Slide your plastic opening tool along the edge of the back cover to pop it open.
During Reassembly this is where the plastic snaps are located on the back cover. They will have to be lined up in order for it to snap back into place correctly.
If the battery connector looks like this, it may not be making perfect contact, and your tablet may not turn on properly.
To reassemble your device, follow these instructions in reverse order. All you have to do is snap in the back cover.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
