Einleitung
The guide will show you how to remove and replace the batteries in your camera.
Was du brauchst
First, open the cover to the batteries. This is located on the bottom left of the camera.
Push the door down and to the left to open. This opens into the batteries and the memory card.
When finished, you should have one battery positive side up and the other one negative side up.
Fast fertig!
To close the door, push the door down and slide to the right
Abschluss
