Zum Hauptinhalt wechseln
Fix Your Stuff
Right to Repair
Parts & Tools
Einleitung
Replacing the camera buttons.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use your finger tip to slide battery cover door away from the center of the camera.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Remove the old batteries.
    • Remove the old batteries.
  3. Remove 7 screws from the outer case with a Phillips #00. All screws are 4.45mm. There are 2 screws on the port side.
    • Remove 7 screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Make sure the battery cap is "up". Pull the outer case off with your hands. Pull the outer case off with your hands.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Remove the necessary broken buttons.
    • Remove the necessary broken buttons.
    • They come out easily so just use your fingers.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Taggart Ashby
315 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 26-19, Regan Spring 2010 Mitglied von Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Mitglieder
7 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 2,600
