Zum Hauptinhalt wechseln
Kodak EasyShare C713 Capacitor Replacement
Was du brauchst
  1. Kodak EasyShare C713 Capacitor Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Capacitor Replacement: Schritt 2, Bild 1 von 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Capacitor Replacement, Outer Case: Schritt 3, Bild 1 von 3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: Schritt 3, Bild 2 von 3 Kodak EasyShare C713 Capacitor Replacement, Outer Case: Schritt 3, Bild 3 von 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Capacitor Replacement: Schritt 4, Bild 1 von 3 Kodak EasyShare C713 Capacitor Replacement: Schritt 4, Bild 2 von 3 Kodak EasyShare C713 Capacitor Replacement: Schritt 4, Bild 3 von 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Capacitor Replacement, Capacitor: Schritt 5, Bild 1 von 2 Kodak EasyShare C713 Capacitor Replacement, Capacitor: Schritt 5, Bild 2 von 2
    • To avoid an electric shock, do not to touch capacitor.
    • The capacitor is located underneath the lens.
    • It is held in place by 4 plastic snaps; it can be easily removed by pulling outward with your fingers.
  6. Kodak EasyShare C713 Capacitor Replacement: Schritt 6, Bild 1 von 1
    • Desolder points connecting capacitor to circuit board.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 26-19, Regan Spring 2010 Mitglied von Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 15
Insgesamt: 4,169
