Einleitung
Removing and replacing the LCD and LCD casing.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Use your finger tip to slide battery cover door away from the center of the camera.
The battery door should spring open.
If this does not happen, gently open the door lifting from the outer bottom side of the camera.
Remove the seven screws from the outer case with a Phillips #00.
All screws are 4.45mm.
There are 2 screws on the port side.
There are 2 screws on starboard side.
There are 3 screws on the bottom.
Put your thumb in the upper right corner of the LCD screen.
Pull the LCD screen out of its outer case with your thumb.
Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
After desoldering the LCD casing, just use your fingers to carefully remove it.
6 weitere Nutzer haben diese Anleitung absolviert.
