Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Removing and replacing the LCD and LCD casing.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use your finger tip to slide battery cover door away from the center of the camera.
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Remove the old batteries.
    • Remove the old batteries.
  3. Remove the seven screws from the outer case with a Phillips #00. All screws are 4.45mm. There are 2 screws on the port side.
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Make sure the battery cap is "up". Pull the outer case off with your hands. Pull the outer case off with your hands.
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. The LCD Screen is hinged at the bottom.
    • The LCD Screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD Screen.
    • Pull the LCD screen out of it's outer case with your thumb.
  6. Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Desolder the two points. One on the port side.
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. After desoldering the LCD casing, just use your fingers to carefully remove it.
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Flip up the black tab on the bottom of the LCD Screen with a fingertip.
    • Flip up the black tab on the bottom of the LCD Screen with a fingertip.
  10. Remove the LCD ribbon cable from inside the black tab.
    • Remove the LCD ribbon cable from inside the black tab.
Abschluss
6 weitere Nutzer haben diese Anleitung absolviert.
Taggart Ashby
315 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 26-19, Regan Spring 2010 Mitglied von Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Mitglieder
7 Anleitungen geschrieben
Thank you... i fixed my old camera lcd.
anthoxman - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 12
Insgesamt: 4,810
