Zum Hauptinhalt wechseln
Einleitung
How to remove the buttons.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Position the camera with the bottom facing up. With your finger, slide the battery cover in the direction of open arrow. The battery cover will spring open, so be careful to lift it up gently.
    • Position the camera with the bottom facing up.
    • With your finger, slide the battery cover in the direction of open arrow.
    • The battery cover will spring open, so be careful to lift it up gently.
  2. Use a Phillips #00 screwdriver to remove the seven 4.5mm screws. There are 2 on the left There are 2 on the right
    • Use a Phillips #00 screwdriver to remove the seven 4.5mm screws.
    • There are 2 on the left
    • There are 2 on the right
    • There are 3 on the bottom
  3. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  4. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off. Firmly grasp and pull back casing off.
    • Firmly grasp and pull back casing off.
  5. Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons. Use #00 screwdriver to pry off buttons.
    • Use #00 screwdriver to pry off buttons.
Abschluss
Alan Galarza
69 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 7-51, Amido Fall 2010 Mitglied von Cal Poly, Team 7-51, Amido Fall 2010
CPSU-AMIDO-F10S7G51
4 Mitglieder
7 Anleitungen geschrieben
Thank you this was very helpful!
carolnelson - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,183
