Einleitung
Use this guide to remove the capacitor.
Was du brauchst
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 screws on the left, 2 screws on the right, 3 screws on the bottom
Keep the battery door open
Firmly grasp the front casing and pull it away from the camera.
Orient the camera with the lens facing you.
Use a Phillips #00 screwdriver to remove the one 2.2mm screw on the plastic bridge.
Lift the plastic bridge off and place it to the side.
Grasp the capacitor, carefully remove it from its holder, and place it off to the side.
