Einleitung
If your Kodak EasyShare C913 screen is cloudy or scratched, use this guide to remove and replace the screen. Special skills needed.
Before replacing screen, you will need to remove batteries and the casing of the camera.
Was du brauchst
Position the camera with the bottom facing up.
Slide the battery cover in the direction of the arrow with your finger gently.
Remove the batteries
Remove the seven 4.5mm screws with a Phillips #00 screwdriver.
2 on the left
2 on the right
3 on the bottom
Keep the battery door open
Firmly grasp the front casing and pull away from the camera.
Locate the 2 solder joints on both sides of the LCD casing.
De-solder the joints.
Gently grasp the lower right side of LCD screen.
Lift the screen out of its casing.
Remove 3mm screw from LCD casing using #00 screwdriver.
Lift the black tab with your finger
Gently remove ribbon from underneath black tab.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
