Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This is a step-by-step guide in replacing the battery door
Ersatzteile
Keine Ersatzteile angegeben.
  1. Open the battery cover.
    • Open the battery cover.
  2. Slide the orange latch sideways to eject the battery.
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
    • Remove 7 screws.
    • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
    • 4 (4.45mm) screws on the bottom of the camera.
    • 2 (2.95mm) screws on the left side of the camera.
  5. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
    • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
  6. Remove the rear camera casing. Remove the front casing.
    • Remove the rear camera casing.
    • Remove the front casing.
  7. Remove loose battery door. Remove loose battery door.
    • Remove loose battery door.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Odessa
55 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-8, Johann Summer 2010 Mitglied von Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,555
