Einleitung
This will show a step-by-step process in replacing the camera's mic.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Open the battery cover.
    • Open the battery cover.
  2. Slide the orange latch sideways to eject the battery.
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery.
  3. Remove 7 screws. 1 (6.25 mm) screw located on the top right corner, next to the view screen. 4 (4.45mm) screws on the bottom of the camera.
    • Remove 7 screws.
    • 1 (6.25 mm) screw located on the top right corner, next to the view screen.
    • 4 (4.45mm) screws on the bottom of the camera.
    • 2 (2.95mm) screws on the left side of the camera.
  4. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard. There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
    • There will be 2 (5.39mm) screws. Remove the screws in order to remove the lanyard.
  5. Remove the rear camera casing. Remove the front casing.
    • Remove the rear camera casing.
    • Remove the front casing.
  6. Remove the top panel screw (1x 4.37mm). Remove the top panel screw (1x 4.37mm).
    • Remove the top panel screw (1x 4.37mm).
  7. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  8. Remove the top panel. Remove the top panel.
    • Remove the top panel.
  9. Remove the back panel screws (1x 3.33mm, and  1x 3.40mm). Remove the back panel screws (1x 3.33mm, and  1x 3.40mm).
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  10. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount.
    • Separate the inner casing from the tripod mount.
  11. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board.
    • Gently pull the orange tab out of the circuit board.
  12. Carefully flip the LCD panel to expose the central circuit board. Carefully flip the LCD panel to expose the central circuit board.
    • Carefully flip the LCD panel to expose the central circuit board.
  13. Remove the (1x 3.33mm) screw from the menu button panel .
    • Remove the (1x 3.33mm) screw from the menu button panel .
  14. Pull the second orange tab from the circuit board and remove the buttons. Pull the second orange tab from the circuit board and remove the buttons.
    • Pull the second orange tab from the circuit board and remove the buttons.
  15. Flip up the LCD screen to reveal the two orange ribbon cables. Disconnect the two ribbons cables from their sockets on the motherboard. Disconnect the two ribbons cables from their sockets on the motherboard.
    • Flip up the LCD screen to reveal the two orange ribbon cables.
    • Disconnect the two ribbons cables from their sockets on the motherboard.
  16. Locate the microphone on top of the camera
    • Locate the microphone on top of the camera
  17. With a pry bar, remove microphone away from camera carefully.
    • With a pry bar, remove microphone away from camera carefully.
  18. Release it from it's pin and desolder
    • Release it from it's pin and desolder
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Odessa
55 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-8, Johann Summer 2010 Mitglied von Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Mitglieder
8 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 1,819
