Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Replace unusable or damaged button.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using your fingernail, open the battery cover.
    • Using your fingernail, open the battery cover.
  2. Slide the orange latch sideways to eject the battery.
    • Slide the orange latch sideways to eject the battery.
    • Remove the battery from the battery slot.
  3. Using a Phillips #00 screwdriver, remove two (5.39 mm) screws next to the battery slot. Remove the metal piece holding down the lanyard, then remove the lanyard. Remove the metal piece holding down the lanyard, then remove the lanyard.
    • Using a Phillips #00 screwdriver, remove two (5.39 mm) screws next to the battery slot.
    • Remove the metal piece holding down the lanyard, then remove the lanyard.
  4. Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera. One (6.25 mm) screw is located on the top right corner, right to the "OK" button. Four (4.45 mm) screws are on the bottom of the camera.
    • Using a Phillips #00 screwdriver, remove seven screws located on the outside case of the camera.
    • One (6.25 mm) screw is located on the top right corner, right to the "OK" button.
    • Four (4.45 mm) screws are on the bottom of the camera.
    • Two (2.95 mm) screws are on the left side of the camera, above the USB port.
  5. Carefully remove the rear camera casing. Carefully remove the front camera casing.
    • Carefully remove the rear camera casing.
    • Carefully remove the front camera casing.
  6. Remove the top panel screw (1x 4.37mm). Remove the top panel screw (1x 4.37mm).
    • Remove the top panel screw (1x 4.37mm).
  7. Remove the top panel. Remove the top panel.
    • Remove the top panel.
  8. Remove the back panel screws (1x 3.33mm, and  1x 3.40mm). Remove the back panel screws (1x 3.33mm, and  1x 3.40mm).
    • Remove the back panel screws (1x 3.33mm, and 1x 3.40mm).
  9. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount. Separate the inner casing  from the tripod mount.
    • Separate the inner casing from the tripod mount.
  10. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board. Gently pull the  orange tab out of the  circuit board.
    • Gently pull the orange tab out of the circuit board.
  11. Carefully flip the LCD panel to expose the central circuit board. Carefully flip the LCD panel to expose the central circuit board.
    • Carefully flip the LCD panel to expose the central circuit board.
  12. Remove the (1x 3.33mm) screw from the menu button panel .
    • Remove the (1x 3.33mm) screw from the menu button panel .
  13. Pull the second orange tab from the circuit board and remove the buttons. Pull the second orange tab from the circuit board and remove the buttons.
    • Pull the second orange tab from the circuit board and remove the buttons.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Michael
63 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-8, Johann Summer 2010 Mitglied von Cal Poly, Team 2-8, Johann Summer 2010
CPSU-JOHANN-R10S2G8
5 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,250
