Zum Hauptinhalt wechseln
Kodak EasyShare M2008 Battery Door Replacement
Was du brauchst
  1. Kodak EasyShare M2008 Battery Door Replacement, Battery: Schritt 1, Bild 1 von 2 Kodak EasyShare M2008 Battery Door Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Kodak EasyShare M2008 Battery Door Replacement: Schritt 2, Bild 1 von 2 Kodak EasyShare M2008 Battery Door Replacement: Schritt 2, Bild 2 von 2
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Kodak EasyShare M2008 Battery Door Replacement, Device Casing: Schritt 3, Bild 1 von 3 Kodak EasyShare M2008 Battery Door Replacement, Device Casing: Schritt 3, Bild 2 von 3 Kodak EasyShare M2008 Battery Door Replacement, Device Casing: Schritt 3, Bild 3 von 3
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Kodak EasyShare M2008 Battery Door Replacement: Schritt 4, Bild 1 von 3 Kodak EasyShare M2008 Battery Door Replacement: Schritt 4, Bild 2 von 3 Kodak EasyShare M2008 Battery Door Replacement: Schritt 4, Bild 3 von 3
    • Gently lift off front and back casing.
  5. Kodak EasyShare M2008 Battery Door Replacement: Schritt 5, Bild 1 von 3 Kodak EasyShare M2008 Battery Door Replacement: Schritt 5, Bild 2 von 3 Kodak EasyShare M2008 Battery Door Replacement: Schritt 5, Bild 3 von 3
    • Remove screws along side.
    • Gently peel off side casing.
  6. Kodak EasyShare M2008 Battery Door Replacement, Battery Door: Schritt 6, Bild 1 von 3 Kodak EasyShare M2008 Battery Door Replacement, Battery Door: Schritt 6, Bild 2 von 3 Kodak EasyShare M2008 Battery Door Replacement, Battery Door: Schritt 6, Bild 3 von 3
    • Open the battery door and identify the retaining pin.
    • Push retaining pin out with small tweezers.
  7. Kodak EasyShare M2008 Battery Door Replacement: Schritt 7, Bild 1 von 3 Kodak EasyShare M2008 Battery Door Replacement: Schritt 7, Bild 2 von 3 Kodak EasyShare M2008 Battery Door Replacement: Schritt 7, Bild 3 von 3
    • Once pin is out halfway, close door to ensure no loose parts get lost.
    • Continue to pull out the remaining length of the pin.
  8. Kodak EasyShare M2008 Battery Door Replacement: Schritt 8, Bild 1 von 2 Kodak EasyShare M2008 Battery Door Replacement: Schritt 8, Bild 2 von 2
    • Gently lift off door cover.
Abschluss
Kyanna
313 Reputation
3 Anleitungen geschrieben
New Mexico State, Team 1-2, Easley Spring 2014 Mitglied von New Mexico State, Team 1-2, Easley Spring 2014
NMSU-EASLEY-S14S1G2
5 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 156
