Zum Hauptinhalt wechseln
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place thumb firmly on battery cover. Slide thumb right, the cover should follow and pop up.
    • Place thumb firmly on battery cover.
    • Slide thumb right, the cover should follow and pop up.
  2. Place thumb on orange tab and pull back towards screen. The battery should pop up.
    • Place thumb on orange tab and pull back towards screen.
    • The battery should pop up.
    • Gently lift battery out.
  3. Remove screws from along outer edge of casing. There are 6 screws in total. Righty tighty, lefty loosey!
    • Remove screws from along outer edge of casing.
    • There are 6 screws in total.
    • Righty tighty, lefty loosey!
  4. Gently lift off front and back casing. Gently lift off front and back casing. Gently lift off front and back casing.
    • Gently lift off front and back casing.
  5. Remove screws along side. Gently peel off side casing. Gently peel off side casing.
    • Remove screws along side.
    • Gently peel off side casing.
Abschluss
Kyanna
313 Reputation
3 Anleitungen geschrieben
New Mexico State, Team 1-2, Easley Spring 2014 Mitglied von New Mexico State, Team 1-2, Easley Spring 2014
NMSU-EASLEY-S14S1G2
5 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 90
