Was du brauchst
Place thumb firmly on battery cover.
Slide thumb right, the cover should follow and pop up.
Place thumb on orange tab and pull back towards screen.
The battery should pop up.
Gently lift battery out.
Remove screws from along outer edge of casing.
There are 6 screws in total.
Lift up ribbon cable fastener with blue plastic opening tool.
Gently pull out lens.
To place new lens, peel off silver tape before inserting ribbon cable into proper slot.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
