Einleitung
The colored panel of this camera can easily become cracked or damaged. This guide will show you how to remove it, so you can easily replace it.
Was du brauchst
First, press in and slide forward the battery latch as indicated by the arrow.
Press down on battery until you hear a click and release it. Battery should easily slide out.
Remove the 3.9 mm frame screws using a Phillips #00 screwdriver.
Fast fertig!
Abschluss
